Author Topic: javadoc-editor stack  (Read 1243 times)
jnairb
  • Hero Points: 11
« on: October 24, 2018, 07:41:46 pm »
I just saw this error on RC3 and also now after loading released 23.0.0 version. With cursor in a javadoc comment, I press C-S-D (javadoc-editor) and it comes up but with no parameters section in the dialog even though the method has parameters.
I tried to reproduce it with a minimal class definition (just the one function), and with that, I get the following error and stack:
Slick-C Error
Invalid number argument
file=javadoc.ex offset=8826
OK
javadoc.ex 8826 _javadoc_form.ctltree1.on_change(10,1)   p_window_id: 13   p_object: OI_EDITOR   p_name:
javadoc.ex 4983 _javadoc_refresh_proctree(1)   p_window_id: 267   p_object: OI_COMMAND_BUTTON   p_name: ctlok
javadoc.ex 13190 _javadoc_form.ctlok.on_create()   p_window_id: 267   p_object: OI_COMMAND_BUTTON   p_name: ctlok
dlgeditv.ex 6413 show(-xy -modal _javadoc_form)   p_window_id: 13   p_object: OI_EDITOR   p_name:
javadoc.ex 14076 javadoc_editor()   p_window_id: 13   p_object: OI_EDITOR   p_name:
This is the test file (a C++ include) that causes the stack:
class LoABC : public RmABC
public:
    * Dump node balancer to VLOG
    * @param vlogEntry  A reference to the VLOG entry to dump data into
    * @param invokeDumpToVlogInternal
    *                   An indication of whether to invoke the
    *                   dumpToVlogInternal() method
   virtual void dumpToVlog(const LogEntry& vlogEntry,
                           Boolean invokeDumpToVlogInternal) const;
  • Hero Points: 483
Re: javadoc-editor stack
« Reply #1 on: October 24, 2018, 11:33:02 pm »
Reproduced.  Will see if I can get this into the first hot fix.
