Author Topic: Show status on file icons - Perforce  (Read 917 times)
peran
« on: October 28, 2018, 08:02:48 pm »
Hello :)
I would like to see the status on the file icons in Slickedit when working with the perforce server, but at the moment they are all grey(ish). I have the "Show status on file icons" on. Other than that everything works as expected. Is there anything else I have to do?
SlickEdit Pro 2018 (v23.0.0.10 64-bit)
OS: Windows 10 x64
OS Version: 10.00.0
Best regards,
P-A
  • Hero Points: 134
Re: Show status on file icons - Perforce
« Reply #1 on: October 29, 2018, 03:26:44 pm »
Are you using the SCC support, or the specialized support?
peran
« Reply #2 on: October 29, 2018, 06:36:57 pm »
I am using the specialized support (command line system selected).
  • Hero Points: 134
« Reply #3 on: October 31, 2018, 10:47:35 am »
I am looking into this
  • Hero Points: 134
« Reply #4 on: November 09, 2018, 03:57:14 pm »
This is fixed for the first hotfix.
redwards
« Reply #5 on: January 04, 2019, 06:22:57 pm »
No, I don't believe it is.
  • Hero Points: 134
« Reply #6 on: January 04, 2019, 06:43:34 pm »
I will take a look at this.
