Author Topic: Select Symbol dialog grows with each open  (Read 427 times)
SeeCwriter
« on: January 11, 2019, 05:24:33 pm »
When you the mouse over a symbol, a pop-up appears with the symbol and a green arrow next to it. When you click the green arrow, the Select Symbol dialog opens with a list of where that symbol is declared/used/etc. Each time the Select Symbol dialog opens, its length grows. And there appears to no end to how large the width will grow. I often shorten it before closing, but it continues to grow each time its opened. This is not a problem, just an annoyance.
I'm using v23.0.0.11 with hotfix se2300_1 installed.
  • Hero Points: 420
Re: Select Symbol dialog grows with each open
« Reply #1 on: June 05, 2019, 10:51:47 pm »
This is fixed in 23.0.2.
