Author Topic: Core dump 2019-Jan-24  (Read 617 times)
  • Hero Points: 118
« on: January 24, 2019, 10:35:27 pm »
Got a core dump. 23.0.0.11 64bit on Centos 7.2, hotfix 1
Read coredump_190124.txt on support.slickedit.com for instructions.
I started a gdb debugging session (had done many before). It did the build first (build_last.log included of this last build, build_full.log contains all builds). Then mysteriously crashed. It think it got past the build and was starting a debugging session, but I'm not sure.
My user.cfg.xml also included in the package.
  • Hero Points: 119
Re: Core dump 2019-Jan-24
« Reply #1 on: January 25, 2019, 01:53:07 pm »
I'll take a look at it this morning.
