Author Topic: Edit Token mapping  (Read 1016 times)
  • Hero Points: 187
Edit Token mapping
« on: February 01, 2019, 07:02:23 pm »
DiffZilla used to have Token mapping --- pretty cool feature, now gone.
To be fair, it was inconvenient at best to use.
DZ could dynamically create mapping candidates.
For example, when comparing a set of files where I've done a bunch of symbol renames, DZ will highlight these with intraline highlights.
If DZ enters each of these into a histogram, then displays that in a list with check boxes (sorted by most frequent occurrence), the user could then show/hide each of the most popular intraline diffs by setting those check boxes.
This would have to work for multifile diffs to be most useful.
  • Hero Points: 137
Re: Edit Token mapping
« Reply #1 on: February 01, 2019, 07:04:19 pm »
This didn't get completed for 23.0 and will be added back in.
  • Hero Points: 187
« Reply #2 on: February 01, 2019, 10:04:05 pm »
With the histogram and check boxes?
