Author Topic: Options and defaults  (Read 1135 times)
  • Hero Points: 192
« on: February 04, 2019, 07:42:19 pm »
I'd like is Options would tell me which items are set to their default values and which items have been customized.
Just a little "*" or something next to each line item that isn't the default value.
Bonus points: Provide a way to reset any individual item to its default, or a way to see what the default value is.
  • Hero Points: 461
Re: Options and defaults
« Reply #1 on: February 04, 2019, 11:35:37 pm »
Not exactly what you are asking for, but there is Tools > Options > Import/Export Options > Restore Default Options...  You can select and restore settings at a pretty fine granularity here.  However, it does not show you which ones you have modified, or your value vs. the default value.  That would be a useful feature to add here, but it would require quite a bit of work on the import/export framework.
