Author Topic: SE does not retain change to GIT executable path  (Read 5137 times)
smiller53
« on: March 07, 2019, 10:21:07 pm »
I'd prefer to not store the SE project, workspace meta data inside the GIT repo containing the code I'm editing in SE.
Thus I did TOOLS->OPTIONS->Tools->Version Control->Version Control Providers->Git and change
Git executable from: /opt/bb/bin/git
                        to:  /opt/bb/bin/git -C %rp
However, the tool does not remember the change. And since the SE project/workspace files are in a different directory
that the code under GIT control, we'll need a -C argument somewhere. Editing vunxdefs.e doesn't help.
  • Hero Points: 146
Re: SE does not retain change to GIT executable path
« Reply #1 on: April 17, 2019, 03:24:40 pm »
 I will look into this.
  • Hero Points: 146
« Reply #2 on: April 17, 2019, 06:04:41 pm »
This option requires the executable to be a valid filename.  I'll have to look at a way to add support for -C in.
  • Hero Points: 146
« Reply #3 on: April 18, 2019, 09:40:29 am »
I can put something in for the -C option, but first I want to better understand how you project and works space are set up.  Can you explain this a little?
TIA
« Last Edit: April 18, 2019, 11:50:47 am by Dan »
  • Hero Points: 146
« Reply #4 on: May 09, 2019, 02:22:03 pm »
