Author Topic: Bug in references window  (Read 1622 times)
asandler
  • Hero Points: 27
« on: May 06, 2019, 04:19:10 PM »
There seems to be a bug in references window in SE. It was introduced with either version 23.0.1 or with one of the latest hot-fixes - I only started noticing it recently. It seems that when you have a bunch of references, first reference in the file and file entry itself point to the same place in the code. See attached screencast.
Alex.
  • Hero Points: 517
Re: Bug in references window
« Reply #1 on: May 06, 2019, 07:48:38 PM »
There was a bug in the most recent hot fix that caused the preview and references window preview not to updated immediately.  It will be fixed in the next hot fix.
asandler
  • Hero Points: 27
« Reply #2 on: May 24, 2019, 09:07:59 PM »
@Denis,
Is there a quick workaround for this problem? I am relying on references search quite a lot and this bug bothers me. Alternatively, what version and hot fix I can roll back to make it disappear?
Thank you
asandler
  • Hero Points: 27
« Reply #3 on: May 31, 2019, 11:43:11 AM »
Just saw new version release. I guess that addresses my concern. Thank you.
