Author Topic: SE doesn't save file configuration through a reboot  (Read 720 times)
jorick
  • Hero Points: 17
« on: May 08, 2019, 02:15:16 pm »
I needed to reboot my computer so I shut down all applications including SE.  After rebooting, SE loaded files that I haven't worked on for months.  This was an orderly shutdown so SE should have reloaded the files I was working on before the reboot.
SlickEdit Pro 2018 (v23.0.0.11 64-bit)
Serial number: WB828481
License file: C:\ProgramData\slickedit\23\slickedit.lic
Build Date: October 30, 2018
Emulation: CodeWright
OS: Windows 7 x64
Memory: 29% Load, 8495MB/28577MB Physical, 9373MB/57152MB Page File, 434MB/8388607MB Virtual
Screen Size: 1680 x 1050, 1680 x 1050, 1680 x 1050, 1680 x 1050, 1920 x 1200
Project Type: Cpp
Language: .c (C/C++)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 23.0.0\ (non-removable drive,NTFS,96316MB free)
Configuration Directory: C:\Users\rbennet\Documents\My SlickEdit Config\23.0.0\ (non-removable drive,NTFS,96316MB free)
Migrated from: C:\Users\rbennet\Documents\My SlickEdit Config\22.0.2\
