Author Topic: First line disapears when cursor moves over "top of file" line  (Read 2959 times)
arnaldo
I'm running SlickEdit Pro 2018 with hotfix_se2301_4_cumulative installed on macOS Mojave (10.14.5).
When editing some files (I've noticed so far with some .css files) whenever I move of the "Top of File" line the first line of the file (line 1) is simply "erased". There is still an empty line and if I save the file, then the blank line replaces the original line.
Undo does not work as SlickEdit does not considers that a change was made, so there is no way to revert except by quit and reload.
Any ideas? Has anyone seem this before?
Thanks in advance!
Arnaldo.
  • Hero Points: 116
Re: First line disapears when cursor moves over "top of file" line
« Reply #1 on: May 15, 2019, 09:34:09 pm »
I can reproduce that with CSS files.  First line vanishes whenever I hover the mouse over that "Top Of Line" line.  We're taking a look at it.
arnaldo
« Reply #2 on: May 15, 2019, 10:09:27 pm »
Thanks for the quick reply! Glad to know that it's easily reproducible.
For the time being I'm keeping the "Top of File" line hidden, so I will not damage CSS files.
  • Hero Points: 419
« Reply #3 on: May 15, 2019, 11:02:15 pm »
Fixed for next hot fix build. This problem is limited to CSS files only. Thanks for letting us know
arnaldo
« Reply #4 on: May 16, 2019, 01:19:37 pm »
Great! Thanks.
Will run without the TOF line until next hotfix!
