Author Topic: git worktree support  (Read 994 times)
TKasparek
  • Hero Points: 27
« on: May 22, 2019, 05:11:12 pm »
I keep getting an error in my Output window:
fatal: not a git repository (or any of the parent directories): .git
I'm assuming this is because I use worktrees to manage many changes as they are in various stages without having to do redo full long tedious builds.
In the worktree directories, the .git folder is replaced by a .git file that references the directory to find the relevant git information.
  • Is this planned on being supported?
  • Is there an easy way I can make this error go away for the time being?
TKasparek
  • Hero Points: 27
Re: git worktree support
« Reply #1 on: May 22, 2019, 05:23:44 pm »
Also, right clicking on a project located in a worktree directory from the Projects window and selecting Version Control->Browse Repo produces the following Slick-C stack:
This property or method is not allowed on this object
svc.ex 10032 svc_gui_browse_repository()   p_window_id: 80   p_object: OI_TREE_VIEW   p_name: _proj_tooltab_tree
ProjectDirectory (has workspace file)
|-->head (actual git repo) (has project file for 'head' project)
|-->worktree dir from head (has project file for 'worktree 1' project)
|-->worktree dir 2 from head (has project file for 'worktree 2' project)
|-->workspace tags dir (keeps actual project dirs cleaner)
  • Hero Points: 137
« Reply #2 on: May 23, 2019, 12:30:51 pm »
What command did you use to make a copy of the repository this way?
Normal git commands work from that tree on a console?
If you run "git rev-parse --show-toplevel" from that path, do you get the root from the copy or the original repository?
  • Hero Points: 137
« Reply #3 on: May 23, 2019, 12:37:12 pm »
Fixed for next hotfix or 23.0.2, whichever comes first.  If you need it immediately please PM me an email address.
Reproduced, working on it.  Tools>Version Control>Browse Repository does work if you're doing the current project.
« Last Edit: May 23, 2019, 01:32:58 pm by Dan »
TKasparek
  • Hero Points: 27
« Reply #4 on: May 23, 2019, 06:12:05 pm »
It's not actually creating a copy of the repository, it's putting a branch (or disconnected head) at specified path.
https://git-scm.com/docs/git-worktree
From any worktree or git clone directory:
git worktree list - will show current worktrees (identified by path) and the branch they are on
git worktree add ../<new worktree dir> <some branch that isn't being used> - will create a new worktree
Delete the folder when you are done.
git worktree prune - will update worktree list and remove tree branches that are no longer found.
So from my example, if I were in the head folder:
<drive/path to folder>/ProjectDirectory/head $ git worktree -b my_branch ../worktree1 origin/HEADwill add a new folder called worktree under ProjectDirectory with a new branch called my_branch that is based off of origin/HEAD
There will be a .git file at ProjectDirectory/worktree1/.git that contains:
gitdir: <drive/path to folder>/ProjectDirectory/head/.git/worktrees/worktree1
<drive/path to folder>/ProjectDirectory/worktree1 $ git rev-parse --show-toplevel
  • Hero Points: 137
« Reply #5 on: May 24, 2019, 09:38:20 am »
We definitely want to support this.  What operation are you performing when you get this error?  So far everything I've tried has worked.
TKasparek
  • Hero Points: 27
« Reply #6 on: May 24, 2019, 01:00:24 pm »
I’m not doing anything specific. The error pops up randomly. Background task for scanning/updating file status icons in the project tree, maybe? My build process also checks out a few other projects to pull from, both git and svn.
Is there a way to get more info when the error?
  • Hero Points: 137
« Reply #7 on: May 28, 2019, 10:42:25 am »
It's possible it could be that or if you have it turned on we automatically detect Git and SVN files, and that runs on a background thread as well, although if there are errors both should fail silently.
So are there one or more functionalities failing, or just an occasional error message that we aren't sure what it's tied to?
