Author Topic: list-buffers dialog not coloring modified buffers  (Read 783 times)
TKasparek
  • Hero Points: 28
« on: May 23, 2019, 08:13:58 pm »
I'm not sure what I changed or if there is a bug, but list-buffers dialog used to color modified non-saved files and I've used this to verify I was good to go do a build (outside of SE). Has something changed here? Is there an option I'm not seeing somewhere?
  • Hero Points: 140
Re: list-buffers dialog not coloring modified buffers
« Reply #1 on: May 24, 2019, 09:40:10 am »
This still seems to work for me in 23.0.1 with the latest hotfixes, although if it is the current file it can be a little tricky to see.
TKasparek
  • Hero Points: 28
« Reply #2 on: May 24, 2019, 01:03:04 pm »
I can modify multiple buffers and don’t see modified coloring in that buffers window, tab colors are changed correctly though.
  • Hero Points: 140
« Reply #3 on: May 28, 2019, 10:39:20 am »
Do you mean the whole filename has changed color (file is modified in memory) or there is a red dot on the icon (file is different from what is in version control)?
TKasparek
  • Hero Points: 28
« Reply #4 on: May 28, 2019, 11:59:55 am »
The whole file name had changed colors.
