Author Topic: SE 23.0.2 Windows x64 no longer showing files in "Directory View"?  (Read 1270 times)
Taeguk
I am running SE 23.0.2.0 64-bit with hotfix_se2302_1_cumulative.zip on Windows 8.1 64-bit and my existing workspace/project is no longer showing files. I have a project that has the "Folder View" set to "Directory View" and no files are shown under the project. If I open the same workspace/project in SE 23.0.1.2 64-bit, the directory of files shows correctly.
I also installed SE 23.02.0 64-bit with hotfix_se2301_1_cumulative.zip on Linux (Ubuntu 14.01) and the "Directory View" is working just fine.
Attached are screen snaps from opening the same workspace/project from SE 23.01.2 and SE 23.02.0 and you can see no directory shown under project for SE 23.0.2.0.
Re: SE 23.0.2 Windows x64 no longer showing files in "Directory View"?
« Reply #1 on: June 11, 2019, 08:31:29 pm »
Thanks for the report.  Is this project files using wildcards?  I am double-checking to make sure but there may be an issue there that needs investigating.
Taeguk
« Reply #2 on: June 11, 2019, 08:57:58 pm »
Yes, it is using recursive with wild cards (*.*).
I did try to create a new workspace/project with wild cards, and noticed the default Folder View did not show files either. Tried switching to Directory View and still did not show files.
Mike
  • Hero Points: 20
« Reply #3 on: June 14, 2019, 03:39:23 pm »
The hotfix that resolves this is available on our website:
https://customer.slickedit.com/index.php?option=com_content&view=article&id=296
