Author Topic: Ada Procedure Not Showing up in Defs Window  (Read 2582 times)
rgloden
  • Hero Points: 5
« on: July 19, 2019, 05:01:51 am »
The in the following Ada example, the package instantiation causes SlickEdit to not display the procedure "dump_all" in the Defs window.  Change package to packagex and SE works correctly (though it wouldn't be valid Ada).
procedure dump_all is
   package int_int_io is new Text_IO.Integer_IO(Integer);
begin -- dump_all
    null;
end dump_all;
SlickEdit Pro 2018 (v23.0.1.1 64-bit)
Windows and Linux
  • Hero Points: 461
Re: Ada Procedure Not Showing up in Defs Window
« Reply #1 on: July 19, 2019, 11:58:55 am »
Reproduced. Looking into this.
SlickEdit Support
  • Hero Points: 26
« Reply #2 on: July 22, 2019, 03:53:49 pm »
PM sent.
SlickEdit Support
rgloden
  • Hero Points: 5
« Reply #3 on: July 22, 2019, 05:17:59 pm »
Thanks.
