Author Topic: Bug in Document Editor  (Read 2708 times)
fritzeflink
« on: August 14, 2019, 04:57:17 pm »
There's a bug in edit-doc-comment that happened to me for the first time today. Up to now it all worked fine but suddenly the dialog looks like in the picture. Clicking on OK does nothing, I have to CANCEL the dialog, and thats that.
  • Hero Points: 447
Re: Bug in Document Editor
« Reply #1 on: August 15, 2019, 12:19:01 am »
Could you attach your <config>/logs/stack.log
fritzeflink
« Reply #2 on: August 15, 2019, 07:37:23 pm »
It happens only for XML documents. When I select Doxygen, it works.
stack[2019-08-08T07:42:19Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T07:42:19Z] Created on 8/8/2019 at 7:42:19 (102 ms)
stack[2019-08-08T07:42:19Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T07:42:19Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T07:42:19Z] run-time error position
stack[2019-08-08T07:42:19Z] error code=-2088
stack[2019-08-08T07:42:19Z] Invalid object handle
stack[2019-08-08T07:42:19Z]xmldoc.ex 11913 _xmldoc_form.ctltree1.on_change(10,3,0)   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:42:19Z]xmldoc.ex 13423 _xmldoc_form.ctlok.on_create()   p_window_id: 482   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-08T07:42:19Z]dlgeditv.ex 6401 show(-xy -modal _xmldoc_form)   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:42:19Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:42:19Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:42:21Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T07:42:21Z] Created on 8/8/2019 at 7:42:21 (37 ms)
stack[2019-08-08T07:42:21Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T07:42:21Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T07:42:21Z] run-time error position
stack[2019-08-08T07:42:21Z] error code=-3015
stack[2019-08-08T07:42:21Z] Invalid argument
stack[2019-08-08T07:42:21Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:42:21Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:42:21Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:44:09Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T07:44:09Z] Created on 8/8/2019 at 7:44:9 (823 ms)
stack[2019-08-08T07:44:09Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T07:44:09Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T07:44:09Z] run-time error position
stack[2019-08-08T07:44:09Z] error code=-3015
stack[2019-08-08T07:44:09Z] Invalid argument
stack[2019-08-08T07:44:09Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:44:09Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:44:09Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:44:09Z]dlgeditv.ex 6202 show(-xy -modal _xmldoc_form)   p_window_id: 488   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T07:44:09Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:44:09Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:44:09Z]stdcmds.ex 8486 command_execute()   p_window_id: 28   p_object: OI_EDITOR   p_name:
stack[2019-08-08T07:44:09Z]stdcmds.ex 8801 split_insert_line()   p_window_id: 4   p_object: OI_TEXT_BOX   p_name:
stack[2019-08-08T08:38:03Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T08:38:03Z] Created on 8/8/2019 at 8:38:3 (428 ms)
stack[2019-08-08T08:38:03Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T08:38:03Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T08:38:03Z] run-time error position
stack[2019-08-08T08:38:03Z] error code=-2088
stack[2019-08-08T08:38:03Z] Invalid object handle
stack[2019-08-08T08:38:03Z]xmldoc.ex 11913 _xmldoc_form.ctltree1.on_change(10,1)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:03Z]xmldoc.ex 6445 _xmldoc_refresh_proctree(1)   p_window_id: 587   p_object: OI_COMMAND_BUTTON   p_name: ctlok
stack[2019-08-08T08:38:03Z]xmldoc.ex 13303 _xmldoc_form.ctlok.on_create()   p_window_id: 587   p_object: OI_COMMAND_BUTTON   p_name: ctlok
stack[2019-08-08T08:38:03Z]dlgeditv.ex 6401 show(-xy -modal _xmldoc_form)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:03Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:03Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:04Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T08:38:04Z] Created on 8/8/2019 at 8:38:4 (746 ms)
stack[2019-08-08T08:38:04Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T08:38:04Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T08:38:04Z] run-time error position
stack[2019-08-08T08:38:04Z] error code=-3015
stack[2019-08-08T08:38:04Z] Invalid argument
stack[2019-08-08T08:38:04Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:04Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:04Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:22Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T08:38:22Z] Created on 8/8/2019 at 8:38:22 (850 ms)
stack[2019-08-08T08:38:22Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T08:38:22Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T08:38:22Z] run-time error position
stack[2019-08-08T08:38:22Z] error code=-3015
stack[2019-08-08T08:38:22Z] Invalid argument
stack[2019-08-08T08:38:22Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:22Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:22Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:22Z]dlgeditv.ex 6202 show(-xy -modal _xmldoc_form)   p_window_id: 441   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T08:38:22Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T08:38:22Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-08T11:50:38Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T11:50:38Z] Created on 8/8/2019 at 11:50:38 (603 ms)
stack[2019-08-08T11:50:38Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T11:50:38Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T11:50:38Z] run-time error position
stack[2019-08-08T11:50:38Z] error code=-2088
stack[2019-08-08T11:50:38Z] Invalid object handle
stack[2019-08-08T11:50:38Z]xmldoc.ex 11913 _xmldoc_form.ctltree1.on_change(10,87,0)   p_window_id: 608   p_object: OI_EDITOR   p_name:
stack[2019-08-08T11:50:38Z]xmldoc.ex 13423 _xmldoc_form.ctlok.on_create()   p_window_id: 761   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-08T11:50:38Z]dlgeditv.ex 6401 show(-xy -modal _xmldoc_form)   p_window_id: 608   p_object: OI_EDITOR   p_name:
stack[2019-08-08T11:50:38Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 608   p_object: OI_EDITOR   p_name:
stack[2019-08-08T11:50:38Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 608   p_object: OI_EDITOR   p_name:
stack[2019-08-08T11:50:40Z] Slick-C STACK TRACE ******************************
stack[2019-08-08T11:50:40Z] Created on 8/8/2019 at 11:50:40 (55 ms)
stack[2019-08-08T11:50:40Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-08T11:50:40Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-08T11:50:40Z] run-time error position
stack[2019-08-08T11:50:40Z] error code=-3015
stack[2019-08-08T11:50:40Z] Invalid argument
stack[2019-08-08T11:50:40Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 524   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T11:50:40Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 524   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-08T11:50:40Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 608   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T03:05:04Z] Created on 8/10/2019 at 3:5:4 (473 ms)
stack[2019-08-10T03:05:04Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T03:05:04Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T03:05:04Z] run-time error position
stack[2019-08-10T03:05:04Z] error code=-2088
stack[2019-08-10T03:05:04Z] Invalid object handle
stack[2019-08-10T03:05:04Z]xmldoc.ex 11913 _xmldoc_form.ctltree1.on_change(10,1,0)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]xmldoc.ex 13423 _xmldoc_form.ctlok.on_create()   p_window_id: 670   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-10T03:05:04Z]dlgeditv.ex 6401 show(-xy -modal _xmldoc_form)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]alias.ex 4359 alias:InsertMacroCall()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]alias.ex 6250 alias:expand_alias_line(edc,%\m edit-doc-comment%,1,5,,<empty>,<empty>,,,466,
stack[2019-08-10T03:05:04Z]   11:   ._typename()=MI-localFunctionParams-t
stack[2019-08-10T03:05:04Z]   11:   .m-param=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-ptype=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-flags=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-rtype=
stack[2019-08-10T03:05:04Z]   11:   .m-exception=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-existingParamName=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-existingParamDesc=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-existingRName=
stack[2019-08-10T03:05:04Z]   11:   .m-existingRDesc=
stack[2019-08-10T03:05:04Z]   11:   .m-existingSummary=
stack[2019-08-10T03:05:04Z]   11:   .m-existingException=<empty>
stack[2019-08-10T03:05:04Z]   11:   .m-signature=
stack[2019-08-10T03:05:04Z]   11:   .m-procName=
stack[2019-08-10T03:05:04Z]   11:   .m-className=
stack[2019-08-10T03:05:04Z]   12:   0
stack[2019-08-10T03:05:04Z]   13:   0
stack[2019-08-10T03:05:04Z]   14:   0
stack[2019-08-10T03:05:04Z]   p_window_id: 533
stack[2019-08-10T03:05:04Z]   p_object: OI_EDITOR
stack[2019-08-10T03:05:04Z]   p_name:
stack[2019-08-10T03:05:04Z]alias.ex 2793 alias:expand_alias2(edc,<empty>,%\m edit-doc-comment%,5,533,466,0,0,1)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]alias.ex 1816 expand_alias(edc,,language.c.aliases,0,1,22 533 466 1 language.c.aliases)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]alias.ex 10725 maybe_auto_expand_alias(edc,edc,language.c.aliases,0)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]c.ex 21749 c:c_expand_space()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:04Z]c.ex 3400 c_space()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:05:07Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T03:05:07Z] Created on 8/10/2019 at 3:5:7 (56 ms)
stack[2019-08-10T03:05:07Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T03:05:07Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T03:05:07Z] run-time error position
stack[2019-08-10T03:05:07Z] error code=-3015
stack[2019-08-10T03:05:07Z] Invalid argument
stack[2019-08-10T03:05:07Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:05:07Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:05:07Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:08:58Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T03:08:58Z] Created on 8/10/2019 at 3:8:58 (828 ms)
stack[2019-08-10T03:08:58Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T03:08:58Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T03:08:58Z] run-time error position
stack[2019-08-10T03:08:58Z] error code=-3015
stack[2019-08-10T03:08:58Z] Invalid argument
stack[2019-08-10T03:08:58Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:08:58Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:08:58Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:08:58Z]dlgeditv.ex 6202 show(-xy -modal _xmldoc_form)   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:08:58Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:08:58Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:08:58Z]stdcmds.ex 8486 command_execute()   p_window_id: 533   p_object: OI_EDITOR   p_name:
stack[2019-08-10T03:08:58Z]stdcmds.ex 8801 split_insert_line()   p_window_id: 4   p_object: OI_TEXT_BOX   p_name:
stack[2019-08-10T03:09:03Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T03:09:03Z] Created on 8/10/2019 at 3:9:3 (302 ms)
stack[2019-08-10T03:09:03Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T03:09:03Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T03:09:03Z] run-time error position
stack[2019-08-10T03:09:03Z] error code=-3015
stack[2019-08-10T03:09:03Z] Invalid argument
stack[2019-08-10T03:09:03Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:09:03Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 446   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T03:09:03Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 482   p_object: OI_FORM   p_name: RUBBERBAND_482
stack[2019-08-10T03:09:03Z]picture.ex 4654 _ul2_image_sizebar_handler(855,9405)   p_window_id: 482   p_object: OI_FORM   p_name: RUBBERBAND_482
stack[2019-08-10T03:09:03Z]xmldoc.ex 12501 _xmldoc_form.ctlimage1.lbutton_down()   p_window_id: 541   p_object: OI_IMAGE   p_name: ctlimage1
stack[2019-08-10T04:53:32Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T04:53:32Z] Created on 8/10/2019 at 4:53:32 (936 ms)
stack[2019-08-10T04:53:32Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T04:53:32Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T04:53:32Z] run-time error position
stack[2019-08-10T04:53:32Z] error code=-2088
stack[2019-08-10T04:53:32Z] Invalid object handle
stack[2019-08-10T04:53:32Z]xmldoc.ex 11913 _xmldoc_form.ctltree1.on_change(10,4,0)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]xmldoc.ex 13423 _xmldoc_form.ctlok.on_create()   p_window_id: 892   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-10T04:53:32Z]dlgeditv.ex 6401 show(-xy -modal _xmldoc_form)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]picture.ex 2780 picture:_on_select_execute(edit-doc-comment,536944640)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]picture.ex 2093 _tbCommand()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:53:32Z]picture.ex 2447 _ul2_picture.lbutton_down(0)   p_window_id: 468   p_object: OI_IMAGE   p_name:
stack[2019-08-10T04:53:34Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T04:53:34Z] Created on 8/10/2019 at 4:53:34 (917 ms)
stack[2019-08-10T04:53:34Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T04:53:34Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T04:53:34Z] run-time error position
stack[2019-08-10T04:53:34Z] error code=-3015
stack[2019-08-10T04:53:34Z] Invalid argument
stack[2019-08-10T04:53:34Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:53:34Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:53:34Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:54:38Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T04:54:38Z] Created on 8/10/2019 at 4:54:38 (706 ms)
stack[2019-08-10T04:54:38Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T04:54:38Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T04:54:38Z] run-time error position
stack[2019-08-10T04:54:38Z] error code=-3015
stack[2019-08-10T04:54:38Z] Invalid argument
stack[2019-08-10T04:54:38Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:38Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:38Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:38Z]dlgeditv.ex 6202 show(-xy -modal _xmldoc_form)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:38Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:54:38Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:54:38Z]picture.ex 2780 picture:_on_select_execute(edit-doc-comment,536944640)   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:54:38Z]picture.ex 2093 _tbCommand()   p_window_id: 504   p_object: OI_EDITOR   p_name:
stack[2019-08-10T04:54:38Z]picture.ex 2447 _ul2_picture.lbutton_down(0)   p_window_id: 468   p_object: OI_IMAGE   p_name:
stack[2019-08-10T04:54:43Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T04:54:43Z] Created on 8/10/2019 at 4:54:43 (8 ms)
stack[2019-08-10T04:54:43Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T04:54:43Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T04:54:43Z] run-time error position
stack[2019-08-10T04:54:43Z] error code=-3015
stack[2019-08-10T04:54:43Z] Invalid argument
stack[2019-08-10T04:54:43Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:43Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:43Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 1336   p_object: OI_EDITOR   p_name: edit1
stack[2019-08-10T04:54:44Z] Slick-C STACK TRACE ******************************
stack[2019-08-10T04:54:44Z] Created on 8/10/2019 at 4:54:44 (317 ms)
stack[2019-08-10T04:54:44Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-10T04:54:44Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-10T04:54:44Z] run-time error position
stack[2019-08-10T04:54:44Z] error code=-3015
stack[2019-08-10T04:54:44Z] Invalid argument
stack[2019-08-10T04:54:44Z]xmldoc.ex 7133 xmldoc:xdResizeChildren(3)   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:44Z]xmldoc.ex 8504 xmldoc:xdResizeControls()   p_window_id: 846   p_object: OI_FORM   p_name: _xmldoc_form
stack[2019-08-10T04:54:44Z]xmldoc.ex 12626 _xmldoc_form.on_resize(0)   p_window_id: 1336   p_object: OI_EDITOR   p_name: edit1
stack[2019-08-12T05:28:13Z] Slick-C STACK TRACE ******************************
stack[2019-08-12T05:28:13Z] Created on 8/12/2019 at 5:28:13 (666 ms)
stack[2019-08-12T05:28:13Z] SlickEdit Pro Version 23.0.1.2 Copyright 1988-2018 SlickEdit Inc.
stack[2019-08-12T05:28:13Z] Edit module and type "st -f <offset>" to get the
stack[2019-08-12T05:28:13Z] run-time error position
stack[2019-08-12T05:28:13Z] error code=-3015
stack[2019-08-12T05:28:13Z] Invalid argument
stack[2019-08-12T05:28:13Z]xmldoc.ex 10134 _xmldoc_form.ctltree1.on_change(10,1,0)   p_window_id: 706   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-12T05:28:13Z]xmldoc.ex 6378 _xmldoc_refresh_proctree(0)   p_window_id: 706   p_object: OI_TREE_VIEW   p_name: ctltree1
stack[2019-08-12T05:28:13Z]xmldoc.ex 6218 xmldoc:xdMaybeSave(1)   p_window_id: 979   p_object: OI_COMMAND_BUTTON   p_name: ctlok
stack[2019-08-12T05:28:13Z]xmldoc.ex 1617 _xmldoc_form.ctlok.lbutton_up()   p_window_id: 462   p_object: OI_EDITOR   p_name: ctlparam3
stack[2019-08-12T05:28:13Z]dlgeditv.ex 7304 show(-xy -modal _xmldoc_form)   p_window_id: 16   p_object: OI_EDITOR   p_name:
stack[2019-08-12T05:28:13Z]xmldoc.ex 14163 xmldoc_editor()   p_window_id: 16   p_object: OI_EDITOR   p_name:
stack[2019-08-12T05:28:13Z]javadoc.ex 13909 edit_doc_comment()   p_window_id: 16   p_object: OI_EDITOR   p_name:
  • Hero Points: 447
« Reply #3 on: August 16, 2019, 06:07:12 pm »
Looks like you got a slick-c stack in the XMLDoc editor, so the next time it came up, it came up in an un-initialized state.
Unless you are consistently getting the Slick-C stack errors, it should resolve itself the next time you bring up XMLDoc.
If you have a test cases where invoking the editor consistently causes a Slick-C stack, then post it here, and that will help me find the problem.
  • Hero Points: 447
« Reply #4 on: August 16, 2019, 07:15:48 pm »
I checked in a hot fix.  The fix will be in the next iteration of the 23.0.2 hot fix, as well as it should make it into v24 beta3.
