Author Topic: B2: Search current procedure in python not available  (Read 2909 times)
  • Hero Points: 122
« on: August 15, 2019, 06:08:57 pm »
On support look for searchprocedurebroken.tar.gz
See README file inside it for repro instructions.
I'm using Linux x64 SE
  • Hero Points: 140
Re: B2: Search current procedure in python not available
« Reply #1 on: August 15, 2019, 06:49:27 pm »
Reproduced.  Looks like it doesn't think the current context is in a function for some reason, we'll look into it.  Thanks for the report.
  • Hero Points: 140
« Reply #2 on: August 15, 2019, 07:52:22 pm »
This is fixed for the next beta.
  • Hero Points: 122
« Reply #3 on: August 15, 2019, 07:53:07 pm »
Thanks Patrick! +1
  • Hero Points: 122
« Reply #4 on: September 21, 2019, 02:44:47 am »
There is still a related issue in B4.
If you go to line 100, the option to "Search Current Procedure" is available in BigFind (for "Find" tab), so that is fixed, however with cursor on line 100 and search for "targetIpAddr" it does not get found. It should be found in multiple places in this procedure but it is not.
  • Hero Points: 467
« Reply #5 on: September 21, 2019, 02:31:00 pm »
Reproduced problem with Python searching within current procedure.  We will look into this.
