Author Topic: Tag Suggestions and multiple cursors  (Read 3271 times)
tchrismadden
« on: August 15, 2019, 10:02:24 pm »
While using multiple cursors in C++ to change a bunch of integers to enum class values I encountered an interesting issue.
Starting with an enum class or enum (I verified that as well):
enum class TestEnumClass
FirstValue,
SecondValue,
ThirdValue
And a set of integer values to be converted to enum constants:
auto x = 0;
auto x2 = 0;
auto x3 = 0;
I set cursors before each of the "0"'s, deleted the "0", and typed TestEnumClass::F. The editor suggested "FirstValue" so I arrowed down to select and enter that.  Only the last cursor inserted the text, resulting in:
auto x = TestEnumClass::F;
auto x2 = TestEnumClass::F;
auto x3 = TestEnumClass::FirstValue;
I have verified that this is an issue in both the osX and windows versions of the beta but have not gone to older versions to see if this was an issue before.
  • Hero Points: 436
Re: Tag Suggestions and multiple cursors
« Reply #1 on: August 16, 2019, 07:21:44 pm »
It is tricky, though.  In your case, yeah, it would have been perfectly valid to insert the completion for all the cursors, but in another case it might not be good.  There is no guarantee that all the cursors are in the same context.
The completion happened to be suggested for the last cursor, so that is where it was processed.  There are really only two solutions (1) disable auto-complete when we have multiple cursors or (2) do a lot of work to do the same insertion for all cursors, potentially creating a real mess in the process.
  • Hero Points: 320
« Reply #2 on: August 17, 2019, 12:27:03 am »
I vote for not doing lots of work...  but I never use multiple cursors  - I do use block mode editing quite a lot which has the same issues.
I was going to suggest copy paste as a workaround  - it does work  - but in the process I discovered a case where auto complete works for all cursors.  In the text below, search for he<space> - there's four of them - then use "set multiple cursors" from mini find.  Then type "he" (no quotes) then the shortcut for autocomplete and choose "hello"  - it gets inserted at all cursors - in beta 2
hellabco abc
hellabco xyzhehabc hello
hellabco abc
hello abc
hello xyzhehabc he
hello abc
hello xyzhehabc he
hello abc
hello xyzhehabc he
hello abc
hello xyzhehabc he
  • Hero Points: 436
« Reply #3 on: September 04, 2019, 10:03:57 pm »
Useful observation Graeme.  The case you found was a word completion, which already has support for multiple cursors.  Studying that code and some other generic code, I found it pretty easy to add support for multiple cursors to auto-complete.  Not going to be in beta3, but possible for the final release.  Block insert mode is going to, of course, stay the same.
