Author Topic: B3: issue with directory view and project wildcard  (Read 9219 times)
Re: B3: issue with directory view and project wildcard
« Reply #15 on: September 25, 2019, 04:02:09 PM »
Does sound very close to the same issue.  How are the wildcards configured, what are include/exclude parameters?
texasaggie97
  • Hero Points: 4
« Reply #16 on: September 25, 2019, 05:48:28 PM »
I have a mix where some files are explicitly listed, and some with wildcards. There are about a dozen files that are explicit, and about half a dozen that use wildcards.
Include filespec: `*.*`
Exclude filespec: `*.pyc;bin\;.cache\;.git\;.tox\`
Recursive: Checked
Show subfolders: Checked
Add as wildcard: Checked and grayed out
Create parent directory folder: Unchecked
