Author Topic: find in current procedure problem  (Read 2995 times)
  • Hero Points: 342
« on: September 26, 2019, 12:11:38 AM »
In previous versions of slick also -
With both mini-find and big-find  - find or replace "look-in" doesn't offer current procedure as a choice if the cursor is in the "function signature" part of the function  - e.g. if the cursor is on a function parameter, you can't select lookin -> current procedure.
Probably not worth spending much time on though.
Re: find in current procedure problem
« Reply #1 on: September 26, 2019, 04:30:59 PM »
Yes, that is a fair criticism.  It only appears in drop-down when in function scope, yet the selection that is created does include the function signature and args.  I'll file a change request and see that we can improve that.
  • Hero Points: 132
« Reply #2 on: September 26, 2019, 04:56:02 PM »
+1
I would also like to be able to search procedure only from the function signature.
