Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2019 v24 Beta Discussion
SlickEdit 2019 (v24.0.0) - Now Available
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: SlickEdit 2019 (v24.0.0) - Now Available (Read 6832 times)
Rodney
SlickEdit Team Member
Senior Community Member
Hero Points: 53
on:
September 27, 2019, 02:23:35 am »
Fixes, Features, and Enhancements in SlickEdit 2019 (24.0.0)
Language Support
New TypeScript Language support
Color Coding
Smart editing features include smart indenting, SmartPaste(TM), and reindenting on Tab.
New YAML Language support
Color Coding
Smart editing features include auto indenting, word completion, and Auto-Close
New Clojure Language support
Color Coding
Project build support
Single file project build support
Kotlin Enhancements
Now with integrated debugging support.
Erlang Enhancements
Added primitive tagging, statement tagging, and function argument help for Erlang.
Markdown Enhancements
Added support for nested emphasis (i.e. _start italic __Bold__ end italic_).
C/C++ Enhancements
Improved preprocessor engine to correctly handle more sophisticated #define macro expansion cases
XML Enhancements
When completing start tags in XML, if there is DTD or Schema information available, the list of start tags will be narrowed down to just the tags in the content model for the parent element.
Project Support
Android support
Support for building newest SDK/NDK levels.
Support for debugging.
Support for Visual Studio 2019 projects.
Support for drag/dropping a directory onto SlickEdit to create a new project and/or add tree of source to the active project.
Support for drag/dropping files or directories onto Project Properties Files tab to add files or a tree of source to the active project.
Support for building with an automatically generated makefile using parallel builds (make -jobs=N).
Support for building project dependencies in parallel when building automatically using vsbuild
Support for invoking compilation commands in parallel when building automatically using vsbuild
Automatically generated Makefiles now include header file dependencies for files in current project
DIFFzilla
Multi-file diff is now multi-threaded by default. This is two to three times faster
Diff speed improvements
Various output optimizations
You can now create a shelf from multi-file diff
Version Control
Add History Diff links to Subversion Repository Browser
Make comment panel on Subversion Repository Browser more readable
Make branches more readable in Git Repository Browser
File Handling
Added right-click context menu item to Document Tabs to get a listing for the directory containing the current file.
File>Open URL... now supports HTTP redirection
Tagging
Added "Auto Collapse" feature to Defs tool window to close automatically expanded tree nodes after you navigate away.
Added "Expand To Statements" feature to Defs tool window. This feature works when "Show Statements" is enabled and, by default, will only expand the tree up to functions rather than expanding all statements for all functions.
Added capability to References tool window to filter references to variables to only show statements where the variable appeared to be assigned to. Note, this does not recongize cases where a class instance calls a non-const method, or cases where a variable is passed to a function by reference.
Added capability to References tool window to filter references to variables to only show statements the symbol is used in a 'const' or 'non-const' context.
Added menu button and label to References tool window to indicate if symbol type filters are in effect. Redesigned filtering so that changing symbol types filters is nearly instant.
Added vertical orientation option to References tool window so that the references preview can be stacked beneath the list of references.
Add "Look in:" option to Symbols tool window to only show a subset of the available tag files.
Debugger
Update GDB to latest version 8.13
For 32-bit compatibility on Windows, SlickEdit now packages a 32-bit GDB (gdb32.exe) with 64-bit SlickEdit.
Fixed activation problems with Debug memory tool window.
Fix bug when attempting to modify memory in the memory tool window for 64-bit apps.
Update LLDB support library to 4.0.1
Find and Replace
Search Results tool window context menu supports sending the results to the References tool window with the new "Send to References" menu item.
Appearance Enhancements
Added font ligature support on Windows (64-bit windows only). macOS version already has font ligature support.
Build window now supports color escape sequences. For example, "g++ -fdiagnostics-color=always myfile.cpp" or "clang++ -fdiagnostics-color=always myfile.cpp" will display colored error messages in the Build window. Cursor movement and non-color escape sequences are not supported. For Unix and macOS, using SoftWrap in the Build Window disables support for bold, italics, and underline.
General
Drastically improved performance for editing remote files where find-first-file/find-next-file operations are very slower. This seems to happen more on Linux and macOS for remote file systems. Windows seems to do a much better good job caching remote directory file lists.
Edit window context menu now has XML Validate and XML Check Well-Formedness menu items.
Not all fixes/changes have been listed.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
