Author Topic: List buffers and closing a file  (Read 899 times)
  • Hero Points: 191
« on: September 28, 2019, 12:24:59 am »
As before, get a history buffer loaded.
In "Files" tool, use Alt+D to close "Version XX of C:\....foo.c"
Since the file is modified, Slick prompts to save it:
SlickEdit Pro
Save changes to 'Untitled<155>'?
Cancel   &Yes   &No
Cancel that.
Now, right click on the file in "Files" tool and select Close.
You'd expect the prompt dialog to be the same, but this time I get:
SlickEdit Pro
Save changes to 'Version 42 of C:\src\plugins\common\rest2.x\csharp-sdk\cspureclient\Rest2SampleApp\CreateApiClient.cs'?
Cancel   &Yes   &No
  • Hero Points: 141
Re: List buffers and closing a file
« Reply #1 on: September 30, 2019, 09:55:21 am »
When you say Files tool, do you mean the Open Tool window?  Or the List Buffers tool window?
  • Hero Points: 191
« Reply #2 on: September 30, 2019, 02:46:02 pm »
list buffers (has three tabs, buffers, project, workspace)
