Author Topic: refactor_quick_rename fails in python  (Read 1567 times)
  • Hero Points: 210
« on: October 01, 2019, 09:06:23 pm »
In python, given this bit of code
def main(args):
    with open("logfile.txt", 'a', newline='') as log_file:
        print("LOG ", args, file=log_file)
Attempting to rename "log_file" fails with
SlickEdit Pro
Definition of 'log_file' not found.
OK
  • Hero Points: 497
Re: refactor_quick_rename fails in python
« Reply #1 on: October 01, 2019, 11:54:48 pm »
Not a quick-refactoring bug per-se.  The problem is that "log_file" is not recognized as a local variable.
I'll file a bug for someone to look into fixing that in the Python parser.
  • Hero Points: 503
« Reply #2 on: October 04, 2019, 12:17:18 am »
Download v24.0.0.8. This is fixed in v24.0.0.8
