Author Topic: v24 Mouse wheel scroll by page  (Read 904 times)
jnairb
  • Hero Points: 11
« on: October 02, 2019, 03:25:04 pm »
I have a Logitech mouse with the settings configured to scroll a page (screen) at a time with the mouse wheel. I'm running Windows 10.
With v24, SlickEdit is scrolling just 3 lines at a time in the editor window. With v23 it did scroll a full page (it scrolled the same amount as pressing Page Up or Down keys). It also scrolls just 3 lines at a time within list dialogs (e.g. list-buffers Files window), while v23 scrolls a page at a time.
Another change with v24 is that the Help windows also now scroll about 3 lines at a time when I use my mouse wheel, while on v23, the scrolling with the mouse wheel in Help windows just scrolled to the bottom or top of the help. (I think I did report that here in the forum sometime in the past.)
How can I get v24 to scroll a complete page at a time when using the mouse wheel in the editor window?
  • Hero Points: 460
Re: v24 Mouse wheel scroll by page
« Reply #1 on: October 02, 2019, 10:27:05 pm »
Reproduced.  Looks like this is a Qt5 difference.  I can fix this for the editor, but would rather not get into it for the help windows (That's Qt's assistant / QtWebKit code).
jnairb
  • Hero Points: 11
« Reply #2 on: October 02, 2019, 10:53:24 pm »
The help scrolling has been broken for me since v20 (https://community.slickedit.com/index.php/topic,11577.msg48963.html) -- the current scrolling in the help is better now than it was if I do accidentally try to scroll in the help. So fixing just for the editor is good enough.
Thanks.
  • Hero Points: 459
« Reply #3 on: October 03, 2019, 06:59:02 pm »
Download 24.0.0.8. Full page wheel scroll will now work in the editor for 64-bit Windows in v24.0.0.8
