Author Topic: Order of projects in Projects tab in SE2019 - a bug?  (Read 1336 times)
djovanovic2
« on: November 05, 2019, 06:13:42 pm »
I've just upgraded from SE2015 to 2019 and projects in "Projects" tab appear in strange order: instead of being simply ordered by project name, as they are in SE2015, in SE2019 I see 2 consecutive alphabetic sequences, one after the other, eg.:  ProjA1, ProjB1, ProjC2 ..., ProjA2, ProjB2, ProjC1...   Cannot see any pattern as to which projects end up in which sequence.
When I open the same workspace in SE2015 it behaves as expected, so this seems to be a bug specific to a newer version.
  • Hero Points: 453
Re: Order of projects in Projects tab in SE2019 - a bug?
« Reply #1 on: November 05, 2019, 09:14:02 pm »
Looking into this
  • Hero Points: 453
« Reply #2 on: November 05, 2019, 09:50:54 pm »
The problem seems to be the "Show relative" option. If you right click and turn that off, then it sorts correctly. This is a bug.
  • Hero Points: 453
« Reply #3 on: November 05, 2019, 10:38:14 pm »
This will be fixed in the next hot fix
djovanovic2
« Reply #4 on: November 06, 2019, 11:46:28 pm »
Thanks for the quick response, the workaround above works  :)
