Author Topic: Property sheet include value shows up as project file (24.0.0.8, hotfix 3)  (Read 716 times)
sigmund
  • Hero Points: 9
Steps to reproduce:
1. Unzip the attached SlickEditTest.zip.
2. In SlickEdit select Project -> Open Workspace... and select the extracted SlickEditTest.sln.
There now is an unexpected file named "SlickEditBug" under Projects, please see the attached image.
SlickEdit does indeed consider "SlickEditBug" a real file, here is for example the output of a workspace search:
Find all "test", "<Workspace>", "*.*", Exclude: "moc_*;ui_*;*.docx"
File D:\SlickEditTest\SlickEditTest\SlickEditTest.cpp
  2 20:#include "SlickEditTest.h"
File D:\SlickEditTest\SlickEditTest\SlickEditTest.h
  3 20:#ifndef SLICK_EDIT_TEST_H
  4 20:#define SLICK_EDIT_TEST_H
Failed to open: D:\SlickEditTest\SlickEditTest\SlickEditBug
Total found: 3     Matching files: 2     Total files searched: 3
Here is the output of Help -> About SlickEdit:
SlickEdit Pro 2019 (v24.0.0.8 64-bit)
Serial number: WB943076
License file: C:\ProgramData\slickedit\24\slickedit.lic
Build Date: October 2, 2019   (State file: October 29, 2019)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 44% Load, 14378MB/32648MB Physical, 19356MB/37512MB Page File, 5102MB/134217727MB Virtual
Shell Information: C:\tools\JPSoft\TCMD25\tcc.exe /LD /LH
Project Type: Microsoft Visual Studio Visual C++
Language: .txt (Plain Text)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 24.0.0\ (non-removable drive,NTFS,94549MB free)
Configuration Directory: C:\Users\VikS\Documents\My SlickEdit Config\24.0.0\ (non-removable drive,NTFS,94549MB free)
Migrated from: C:\Users\VikS\Documents\My SlickEdit Config\23.0.2\
Hotfixes:
C:\Users\VikS\Documents\My SlickEdit Config\24.0.0\hotfixes\hotfix_se2400_3_cumulative.zip (Revision: 3)
« Last Edit: November 06, 2019, 02:32:30 pm by sigmund »
  • Hero Points: 454
Re: Property sheet include value shows up as project file (24.0.0.8, hotfix 3)
« Reply #1 on: November 06, 2019, 03:25:16 pm »
This isn't hot fixable. This will be fixed in 24.0.1. No date set yet. Should be out before the end of the year.
