Author Topic: MacBook scrolling with trackpad resets to top constantly.  (Read 582 times)
TKasparek
  • Hero Points: 27
« on: November 07, 2019, 02:52:24 pm »
On my MacBook Pro, when scrolling in a source file using the trackpad, every time I scroll down the window resets to the top of the file first and then starts the scrolling. It works fine if I use a mouse.
I've seen SE crash a couple of times while scrolling with the trackpad as well.
SlickEdit Pro 2019 (v24.0.0.8)
Serial number: WMX110555
License file: /Library/Application Support/SlickEdit/24/slickedit.lic
Build Date: October 2, 2019   (State file: October 29, 2019)
Emulation: CUA
OS: macOS
OS Version: 10.14.6
Processor Architecture: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 64 bit (8 cores)
Memory: 90% Load, 14763MB/16384MB Virtual
Shell Information: /Applications/SlickEditPro2019.app/Contents/MacOS/secsh -i
Screen Size: 1920 x 1200
Project Type: Cpp
Language: .cpp (C/C++)
Encoding: Automatic
Installation Directory: /Applications/SlickEditPro2019.app/Contents/
Configuration Directory: /Users/tk7186238/Library/Application Support/SlickEdit/24.0.0/
Migrated from: /Users/tk7186238/Library/Application Support/SlickEdit/23.0.2/
Hotfixes:
/Users/tk7186238/Library/Application Support/SlickEdit/24.0.0/hotfixes/hotfix_se2400_3_cumulative.zip (Revision: 3)
  • Hero Points: 438
Re: MacBook scrolling with trackpad resets to top constantly.
« Reply #1 on: November 07, 2019, 03:47:57 pm »
The crash issue popped up a few years ago, and we never had a good enough reproducible case to get to the bottom of it.  I very simple workaround is to turn off drag/drop of text.
Tools > Options > Editing > General / "Allow drag drop of text" to "OFF".
I was not able to reproduce the jumping issue, but I don't have an MBP (Mac mini with Magic Trackpad).  It could be an accidental page gesture, but I'm just guessing here.  Apple has myriads of trackpad options (under TrackPad and then more under Accessiblity), so reproducing the issue might require just the right hardware and settings.
