Author Topic: Alias pop-u... oh, it's gone  (Read 3537 times)
  • Hero Points: 465
Re: Alias pop-u... oh, it's gone
« Reply #15 on: November 08, 2019, 05:14:21 pm »
Try this:
1) Put the attached "autocomplete.e" in your config/hotfixes/ directory.
2) Load it (macro > Load Module...)
3) Do what you do to reproduce the problem.
4) Immediately afterward, go to the SlickEdit debug window and hit Ctrl+X to copy the contents
5) paste that information into a reply
6) Re-load the original <installdir>/macros/autocomplete.e
dunkers
  • Hero Points: 35
« Reply #16 on: November 08, 2019, 05:31:22 pm »
Er, how do I get to the SE debug window? Never needed it before...
  • Hero Points: 465
« Reply #17 on: November 08, 2019, 05:33:52 pm »
Right-click on SlickEdit in the Dock, and select Show All windows.
dunkers
  • Hero Points: 35
« Reply #18 on: November 08, 2019, 05:40:59 pm »
This is Windows so there is no dock per se. Loading the macro gives me a window that lists a load of info lines - is that it? Anyway, this is what it shows when I do my thing:
AutoCompleteUpdateInfo: FOCUS WINDOWS NOT VALID
I get more of those if I hang about longer!
  • Hero Points: 465
« Reply #19 on: November 08, 2019, 06:30:15 pm »
There should be more to it than just that.  I'm attaching another version with a little more debug.
dunkers
  • Hero Points: 35
« Reply #20 on: November 08, 2019, 06:44:27 pm »
just a little bit more this time! Attached.
  • Hero Points: 465
« Reply #21 on: November 08, 2019, 10:02:58 pm »
That did the trick.  Thanks for your patience and fortitude drilling down on this problem.  This will be fixed in the next hot fix for 24.0.0.
dunkers
  • Hero Points: 35
« Reply #22 on: November 08, 2019, 10:25:10 pm »
Blinding, thank you :)
dunkers
  • Hero Points: 35
« Reply #23 on: December 04, 2019, 06:57:46 pm »
Confirmed fixed in hotfix 5, thanks very much  8)
  • Hero Points: 465
« Reply #24 on: December 04, 2019, 11:45:24 pm »
Just an FYI, the original hot fix 5 had some issues.  It would be a good idea to download the new version and install it.
dunkers
  • Hero Points: 35
« Reply #25 on: December 04, 2019, 11:48:53 pm »
Will do, thanks.
