Author Topic: Find Dialog after Hotfix 5 is messed up  (Read 696 times)
  • Hero Points: 187
« on: December 04, 2019, 01:23:41 am »
See attached image.
  • Hero Points: 447
Re: Find Dialog after Hotfix 5 is messed up
« Reply #1 on: December 04, 2019, 04:16:34 pm »
Reproduced.  We may need to rebuild the hot fix.
  • Hero Points: 447
« Reply #2 on: December 04, 2019, 11:45:55 pm »
Please download and install hot fix 5 again.
SlickEdit Support
  • Hero Points: 26
« Reply #3 on: December 05, 2019, 02:12:23 pm »
PM sent.
  • Hero Points: 187
« Reply #4 on: December 05, 2019, 08:29:46 pm »
It works now -- I had to use 'unload-hotfix' first, then load the updated hotfix 5.
sigmund
  • Hero Points: 8
« Reply #5 on: January 06, 2020, 04:23:14 pm »
In SlickEdit v24.0.1.0 the Find and Replace dialog has some help icons that look broken, please see the attached image.
Here is my Help -> About SlickEdit output:
SlickEdit Pro 2019 (v24.0.1.0 64-bit)
Serial number: WB943076
License file: C:\ProgramData\slickedit\24\slickedit.lic
Build Date: December 19, 2019
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 53% Load, 17581MB/32648MB Physical, 26849MB/37512MB Page File, 4920MB/134217727MB Virtual
Shell Information: C:\tools\JPSoft\TCMD25\tcc.exe /LD /LH
Project Type: Microsoft Visual Studio Csharp
Language: .cs (C#)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 24.0.1\ (non-removable drive,NTFS,87366MB free)
Configuration Directory: C:\Users\VikS\Documents\My SlickEdit Config\24.0.1\ (non-removable drive,NTFS,87366MB free)
Migrated from: C:\Users\VikS\Documents\My SlickEdit Config\24.0.0\
  • Hero Points: 447
« Reply #6 on: January 06, 2020, 06:09:20 pm »
Yes, those definately do not look good in that font size.  I'll tweak the code a bit.  It looks like they are being scaled.
