Author Topic: C++ push-tag-filter-overloads bug when function NOT overloaded  (Read 1002 times)
  • Hero Points: 132
« on: December 05, 2019, 03:06:41 pm »
Look for nooverload.tar.gz on support.
Follow instructions in the README file.
  • Hero Points: 488
Re: C++ push-tag-filter-overloads bug when function NOT overloaded
« Reply #1 on: April 09, 2021, 09:53:41 pm »
This bug will be fixed in the next iteration of the 25.0.1 hot fix (Revision 9).
Thanks for the detailed sample code and instructions, and thanks for your patience on this one.  Let me know if you have any problems with the fix when you get it.
