Author Topic: core dump 2019 Dec 11  (Read 1324 times)
Re: core dump 2019 Dec 11
« Reply #15 on: December 18, 2019, 12:14:06 pm »
I'll look back at that case and see if that makes more sense given what I've seen with Rowbearto's core dumps.
It's a tough one to track down, I haven't been able to reproduce anything with or without xretrace.  I started looking at xretrace because I realized (a little late) the only reported coredumps on linux for v24 post beta were with it. It may end up being just a coincidence.
  • Hero Points: 121
« Reply #16 on: December 18, 2019, 04:26:16 pm »
I'm able to reproduce it immediately without xretrace!
I unloaded all xretrace modules and deleted my state file.
Then I load the python file that I sent you, turn on soft wrap (Patrick: Did you enable soft wrap?), go to the very end of line 189 (closing quote), press <ENTER> and crash right away.
Patrick: Make sure you:
1) Use my user.cfg.xml
2) Turn on soft wrap
3) Go to the end of line 189, just after the closing quote, and press <ENTER>
If there are any more files I can provide you let me know.
  • Hero Points: 121
« Reply #17 on: December 18, 2019, 04:28:13 pm »
Patrick:
All my core dumps post beta for v24 were not with xretrace. Only this one was. The first time that I loaded xretrace was on December 8. So all the core dumps I gave you before Dec 8 did not have xretrace.
  • Hero Points: 121
« Reply #18 on: December 18, 2019, 04:32:11 pm »
There are 2 other macros that I have had loaded the whole time. I unloaded both of them, deleted my state file and I was able to repro it again. So it is not my macros either.
After deleting the state file, I relaunched SE, went to line 189, turned on soft wrap, went to the end of line 189 after the quote, pressed <ENTER>, and crash right away.
  • Hero Points: 325
« Reply #19 on: December 18, 2019, 09:31:53 pm »
I was very pleased and impressed that you looked at xretrace and managed to notice an obscure problem.  Any more comments you have are very welcome.
