Author Topic: How to import the options which exported by the old vesion(v14)?  (Read 501 times)
koji
« on: December 30, 2019, 11:03:31 am »
I have a options which exported by v14, when i import the options by v19,  it can't support.
can sb help me? :)
  • Hero Points: 325
Re: How to import the options which exported by the old vesion(v14)?
« Reply #1 on: December 30, 2019, 09:26:24 pm »
You could try getting slickedit to migrate them instead of using export  / import.  If you have paths
myconfig/14.0.0
and
myconfig/19.0.0
Rename 19.0.0 to something like 19.0.0-hide
Then launch vs.exe with
vs.exe +new -sc myconfig
Slickedit will create the folder myconfig/19.0.0 and it may try to copy some settings from the 14.0.0 folder  -  or it might not.
You're probably better off to start from scratch and use slickedit's "quick config" when you launch it.  If you have lots of non default keybindings you could try using export / import in the keybindings dialog.
