Author Topic: Running shell programs  (Read 5808 times)
hensh
« on: March 20, 2020, 11:06:43 AM »
The Slick-C code below will not run. However, if Typora.exe is in my PATH, the commented line below works. Why can't Slick-C find 'C:\Program Files\Typora\Typora.exe'? I've tried numerous variations. What am I missing?
#include "slick.sh"
_command void runtypora() name_info(','VSARG2_READ_ONLY|VSARG2_REQUIRES_EDITORCTL)
   if (_no_child_windows()) {
      _message_box("No buffer is open");
      return;
   if (_isno_name(p_DocumentName) || p_buf_name == '') {
      return;
   save();
   //shell('Typora ' p_buf_name, 'QA');
   shell('C:\Program Files\Typora\Typora.exe ' p_buf_name,'QA');
  • Hero Points: 153
Re: Running shell programs
« Reply #1 on: March 20, 2020, 11:09:38 AM »
Try putting double quotes around C:\Program Files\Typora\Typora.exe  since there are space in it.
If you had this in a variable you could use _maybe_quote_filename() around it.  You still could, but since you have a constant, it's easy enough to just quote.
hensh
« Reply #2 on: March 20, 2020, 02:25:27 PM »
This was the first thing I tried.
shell("C:\Program Files\Typora\Typora.exe " p_buf_name,'QA');
The macro does not compile and I get a message stating that there is an illegal character with a blinking cursor appearing between the colon and the backslash.
  • Hero Points: 153
« Reply #3 on: March 20, 2020, 02:33:14 PM »
Try this:
shell(_maybe_quote_filename('C:\Program Files\Typora\Typora.exe')' 'p_buf_name,'QA');
hensh
« Reply #4 on: March 20, 2020, 02:42:12 PM »
Worked like charm. Thank you. Any idea why your suggestion was necessary?
  • Hero Points: 153
« Reply #5 on: March 20, 2020, 03:36:00 PM »
Because I answered you before I had coffee ;)
In Slick-C, like in C++, \ escapes certain characters in a double quoted string.  For example, "\t" is a tab character.  "\P" is invalid.
Using single quoted strings gets around this.  However, when you have a filename with spaces like that, you still need to double quote them most of the time.
hensh
« Reply #6 on: March 20, 2020, 06:03:26 PM »
 ;D
thanks
