Author Topic: HCL/Terraform support  (Read 6237 times)
fistfullofbeer
« on: April 22, 2020, 08:52:52 PM »
Hi,
I was wondering if this is something that is already supported or is planned to be supported?
Thanks.
  • Hero Points: 151
Re: HCL/Terraform support
« Reply #1 on: April 23, 2020, 03:18:07 PM »
No, it wasn't on our radar.  I might be able to look at some basic editing and coloring support for v25, if I have time in my schedule.  In some ways it looks like extensions on some very JSON-ish syntax.
fistfullofbeer
« Reply #2 on: April 23, 2020, 04:38:18 PM »
That would be awesome Patrick. While I do have IntelliJ IDE, I enjoy using slickedit since its lighter on resource usage and I like mixing it up .. :)
fistfullofbeer
« Reply #3 on: May 20, 2021, 08:33:56 PM »
Just checking in to see if any changes have been made in this area Patrick. Can you please provide and update when possible?
Thanks.
  • Hero Points: 151
« Reply #4 on: May 21, 2021, 02:15:40 PM »
This is in for v26.  We'll ping this thread when the v26 betas come out so you can give it a spin.
fistfullofbeer
« Reply #5 on: May 21, 2021, 03:36:45 PM »
Excellent. Thanks!
pbrightly
  • Hero Points: 6
« Reply #6 on: June 29, 2021, 08:52:26 PM »
Sweet. I was just going to ask for this. :)
  • Hero Points: 151
« Reply #7 on: July 30, 2021, 02:11:09 PM »
