Author Topic: strong behavior about system verilog beautify  (Read 2618 times)
ycyang
« on: May 29, 2020, 02:32:03 AM »
I use system verilog beautify recently, but I got the strong result. Any one had some issue?
Original code :
module test_case();
    logic [7:0] slave_cmd_reg;
    logic [7:0] slave_rdata_low_reg;
    logic [7:0] slave_rdata_high_reg;
    task automatic assign_0x4c_reg();
        case (slave_cmd_reg)
            8'h00:
                {slave_rdata_low_reg} <= 'd0;
            8'h01:
                {slave_rdata_high_reg, slave_rdata_low_reg} <= 'd0;
            default:
                {slave_rdata_low_reg} <= 8'h0;
        endcase
    endtask
endmodule
After beautify:
module test_case();
            8'h00:
                8'h01:
                default:
                endcase
        endtask
        endmodule
  • Hero Points: 151
Re: strong behavior about system verilog beautify
« Reply #1 on: May 29, 2020, 01:51:21 PM »
I can reproduce it, and it looks like it may be a parsing error in the beautifier.  I'll take a look at it.  I suspect this won't be hot-fixable, but would need to be fixed for the next point or major release.
ycyang
« Reply #2 on: May 30, 2020, 02:32:07 AM »
thank you for the update.
  • Hero Points: 151
« Reply #3 on: July 28, 2020, 08:22:14 PM »
This was not hot-fixable.  The fix will be in the upcoming beta 2 for SlickEdit 2020 v25.
