Author Topic: build creates file tab  (Read 661 times)
wbullaughey
« on: July 27, 2020, 05:56:40 pm »
When I do a build command a new file tab gets created which has the same contents as what is displayed in the build window. If the tab already exists it gets reused of following builds.
This also happens in the current regular release.
  • Hero Points: 147
Re: build creates file tab
« Reply #1 on: July 27, 2020, 07:37:55 pm »
That sounds like what happens when you right click in your Build window, and check the "Send Output To Editor Window" entry.  That showing up checked for you?
wbullaughey
« Reply #2 on: July 27, 2020, 09:55:07 pm »
That was set. No idea how it got set originally.
Thanks, Wayne
