Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Bug In "Expand/Clapse block"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bug In "Expand/Clapse block" (Read 4627 times)
skywolf
Community Member
Hero Points: 0
on:
June 30, 2007, 05:26:59 am »
It is OK for if/for/while block, but not good for function/switch block. if collapse a function or witch block, it eats the end "}" and following blank line, and cause problems when trying to add new line after the collapsed block.
Logged
SlickEdit Team Member
Senior Community Member
Hero Points: 509
Re: Bug In "Expand/Clapse block"
Reply #1 on:
July 02, 2007, 04:24:47 pm »
What language? Example please?
Logged
skywolf
Community Member
Hero Points: 0
Reply #2 on:
July 05, 2007, 08:15:32 pm »
c language
Logged
Hero Points: 509
Reply #3 on:
July 05, 2007, 08:54:21 pm »
This is too minor to stick into the hot fix, so I'll just tell you how to fix that problem.
Go to line 2206 of slickedit/macros/cutil.e, and add a case for the "switch" keyword.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
