Author Topic: Feature request: Add multiple trees to project  (Read 446 times)
jc44
  • Hero Points: 22
« on: August 11, 2020, 02:09:43 pm »
[Win 10, x64, Brief]
It would make me very happy if Project/Project Properties/Add Tree supported multi-select so I could add a few trees at once.  When dealing with large source trees I often only want to look at a subset of the directories and it is just annoying to have to go via Add Tree multiple times (especially as the tree I'm looking at has selected the thing I selected last time and collapsed its containing directory so I have to expand that again and scroll down to where I was before continuing).
Thanks
  • Hero Points: 482
Re: Feature request: Add multiple trees to project
« Reply #1 on: August 11, 2020, 05:20:58 pm »
One thing you can do which is pretty close to what you want is select multiple directories in the file explorer and drag them onto SlickEdit. SlickEdit will prompt for each directory but once you have the settings/wildcards/excludes set all you need to do is press Enter.
