Author Topic: Search question  (Read 567 times)
photometer
Search question
« on: September 10, 2020, 05:47:52 pm »
I would like to select a word in the source code and do ctrl+shift+f to invoke the Find in Files dialog box. I would like the "Search for" to automatically contain the selected text rather than typing it in the text box. Is that possible?
  • Hero Points: 206
Re: Search question
« Reply #1 on: September 10, 2020, 10:21:49 pm »
In the Find dialog you right-click (in empty space) and pick "Configure Options...".
Or: Tools > Options > Editing > Search
Set the "Selected text (if exists) option to ON.
photometer
Re: Search question
« Reply #2 on: September 11, 2020, 04:06:18 am »
Thanks, that did solved it.
