Author Topic: Python debugger: None is a string?  (Read 1127 times)
  • Hero Points: 210
« on: September 25, 2020, 10:37:39 pm »
In Locals a variable with the value None is displayed as a string.
"None".
  • Hero Points: 148
Re: Python debugger: None is a string?
« Reply #1 on: September 28, 2020, 01:32:47 pm »
Fixed for the next build.  In passing, I also found and fixed a case where some object instances could be displayed as opaque objects you couldn't expand.
