Author Topic: Python debugger: Typing in the watch window  (Read 967 times)
  • Hero Points: 209
« on: September 25, 2020, 10:40:40 pm »
Populate watches with a few things.
Select one and start typing.
The first character you type changes the item to an edit field, but the typed character is lost.
If it is going to auto-edit like this it shouldn't loose the first character.
It is OK, for example, for <enter> to change it to an edit field - and otherwise be dropped.
