Author Topic: C language: CAN NOT parse anonymous struct which is located in one union;  (Read 2263 times)
Tiger
struct anonymous_t
    int b1                           :  1;
    int b2                           :  1;
    int b3                           :  1;
    int b4                           :  1;
    int b5                           :  4;
    int resv                                  : 24;
typedef union ctrl_u
{    int u32;
    struct anonymous_t; /* anonymous struct */
} T_CTRL;
int main ()
    T_CTRL reg;
     reg.b6 = 0; /* cant complete reg.b6 */
    return 0;
there is an old topic files many years ago,
https://community.slickedit.com/index.php/topic,1973.msg8272.html#msg8272
but this issue still not fixed in my version SlickEdit Pro 2018 (v23.0.0.10 64-bit)
there are lots of header file is created automatically by digital design tool;
this union is used to access register bit;
it's very convenient to use reg.b1 instread of reg.xxx.b1;
most important , this anonymous struct is supported by stand C:
why slickedit not support?
  • Hero Points: 521
I was not aware that was even allowed.  I will look into it and see if a simple fix can be done for v25.
  • Hero Points: 521
This will be handled in SlickEdit 2020 (version 25).
Note, those cases in that older set of posts probably did not work correctly because of the "__no_init" extension being used.  You can work around that by defining it in your C/C++ Preprocessing options.
Tiger
int main ()
    T_CTRL reg;
     reg.b1 = 0; /* cant complete reg.b1 */
    return 0;
sorry, it should be "reg.b1" , NOT "reg.b6"
Tiger
in vscode it can be parsed;
see attached image;
