Author Topic: RC1, MacOS, Can't paste path in "Go to the folder" dialog  (Read 3618 times)
tuchman
  • Hero Points: 7
« on: September 29, 2020, 05:19:01 am »
AFAIK, this has been a problem in 2019 version as well.
Pain threshold just happened to be exceeded in this version.
Can be easily reproduced.
1. Create empty file (new_file)
2. Attempt to save file (Cmd-s)
-> "Save As" edit field contains "Untitled"
3. Enter forward slash in Save As edit field.
->This raises the "Go to the folder:" dialog
5. Try Copy/Paste operations in edit field
-> Copy paste not possible - only hear error bell
Thanks in advance!
SlickEdit Pro 2020 (v25.0.0.5)
Build Date: September 24, 2020
Emulation: macOS
OS: macOS
OS Version: 10.15.6
Processor Architecture: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz 64 bit (16 cores)
Memory: 97% Load, 16038MB/16384MB Virtual
Shell Information: /Applications/SlickEditPro2020.app/Contents/MacOS/secsh -i
Screen Size: 1680 x 1050
Project Type: Perl
Language: . (Plain Text)
Encoding: UTF-8, no signature
Installation Directory: /Applications/SlickEditPro2020.app/Contents/
Configuration Directory: /Users/tuchman/Library/Application Support/SlickEdit/25.0.0/
Migrated from: /Users/tuchman/Library/Application Support/SlickEdit/24.0.2/
Spill File: /tmp/$slk.tuchman.78571
  • Hero Points: 480
Re: RC1, MacOS, Can't paste path in "Go to the folder" dialog
« Reply #1 on: September 29, 2020, 02:34:12 pm »
Reproduced and filed.  This is a native dialog, so that makes the problem a bit more intriguing.  Thanks for reporting this.
tuchman
  • Hero Points: 7
« Reply #2 on: September 29, 2020, 03:06:42 pm »
You might consider looking at BBEdit's "save as" dialog.
Copy/Paste works as expected there.
  • Hero Points: 480
« Reply #3 on: January 20, 2021, 03:21:35 pm »
Thanks again for reporting this.  Little details like this matter.  This will be fixed in the next release of SlickEdit (either 25.0.2 or 26.0.0).
