Author Topic: Export Options Error  (Read 1285 times)
patrickkox
  • Hero Points: 6
  • Debian GNU/Linux user
« on: September 29, 2020, 05:41:37 pm »
I don't know if this is I bug or not, but when I tried to export all my configuration settings there were 2 Error messages.
They don't provide much detail only this:
Type : Export Options Error Message
Source File : [empty]
Line : 1
Description Error #1 : Numbers > Float: Error Retrieving Value
Description Error #2 : Numbers > Double: Error Retrieving Value
Creator : Export Options
That's all I get.
edit: It also shows these error messages when importing these settings onto another computer.
  • Hero Points: 484
Re: Export Options Error
« Reply #1 on: September 29, 2020, 09:06:25 pm »
Something must be off/different in your config. This can't be reproduced with default configs.
Please post your user.cfg.xml
  • Hero Points: 480
« Reply #2 on: September 29, 2020, 09:15:49 pm »
Reproduced.  They can be corrected by going to Debug > Debugger Options... > Numbers, and resetting "Float" and "Double" to "Default".
« Last Edit: September 29, 2020, 09:21:03 pm by Dennis »
patrickkox
  • Hero Points: 6
« Reply #3 on: September 30, 2020, 08:45:05 am »
It's too long to post here, so here is a link to dropbox : [size=78%]https://www.dropbox.com/s/hsdea67a843av9b/user.cfg.xml?dl=0[/size]
patrickkox
  • Hero Points: 6
« Reply #4 on: September 30, 2020, 08:46:48 am »
Yes, that fixed it, Thanks!
