Author Topic: show full path in "list user macros" dialog  (Read 1175 times)
  • Hero Points: 342
« on: February 03, 2021, 07:15:58 AM »
It would be helpful if slick could show the full path to a file in the "list user macros" dialog in a tooltip so that I can tell whether slick is using a macro file from the current configuration folder or an older folder. If I look in the slick c tag files dialog, slick often ends up with some of my macro files from an older configuration folder when they should all be from the latest config folder.  This might be user error but it would help if I could see the path in the "list user macros" dialog  - rather than having to assume that the folders are all relative to the current configuration folder  - though I think this is not the case because I have xretrace in config/UserMacros/xretrace/* and list user macros shows xretrace as xretrace/xretrace.ex.   - or maybe def_macfiles doesn't get updated correctly when you switch the location of a macro file.
