Author Topic: hotfix_se2501_2 stack with Preview and Files or Open tools  (Read 196 times)
at5dapa1
  • Hero Points: 19
« on: February 08, 2021, 07:35:03 pm »
New install, new config, added hotfix_se2501_2 stack.
Preview is configured to activate from all other windows (except Unit Test).
Preview is docked to right, Files and Open tools are docked to right.
Opening Files or Open tools trigger "tagwin.ex 10982 tagwin:_UpdateOneTagWindow(139," see more in attached log.
SlickEdit Pro 2020 (v25.0.1.0 64-bit)
Serial number: WB951378
License file: C:\ProgramData\slickedit\25\slickedit.lic
Build Date: December 16, 2020   (State file: February 3, 2021)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 14% Load, 4659MB/32475MB Physical, 5530MB/32475MB Page File, 4643MB/134217727MB Virtual
Screen Size: 1920 x 1200 (1920 0 1920 1200), 1920 x 1200 (0 0 1920 1200)
Language: No file open
Encoding: No file open
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\25.0.1\ (non-removable drive,NTFS,130617MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\config\25.0.1\ (non-removable drive,NTFS,130617MB free)
Hotfixes:
D:\tools\totalcmd\Tools\dev\SlickEdit\config\25.0.1\hotfixes\hotfix_se2501_2_cumulative.zip (Revision: 2)
  • Hero Points: 459
Re: hotfix_se2501_2 stack with Preview and Files or Open tools
« Reply #1 on: February 09, 2021, 02:25:05 am »
Drat.  Will work on a fix to the fix tomorrow.
  • Hero Points: 459
« Reply #2 on: February 09, 2021, 05:06:22 pm »
Try this fix.  We will also be publishing an updated version of hotfix 2 with this fix integrated.
at5dapa1
  • Hero Points: 19
« Reply #3 on: February 09, 2021, 06:50:43 pm »
Thank you, it works now!  :)
