Author Topic: Config setting for Standard Find Next, and no minimap  (Read 154 times)
slExplorer
« on: February 17, 2021, 04:29:27 pm »
Hi,
I'm looking through the configuration options, but cannot figure out how to change two items.
1.  I'd like
     Find Next
to be set to F3, rather than <Ctrl>G.  But I don't know which emulation defaults to this ; I thought it was CUA, but am wrong about it.
2.  Where is a View Minimap default that I can set to off?  I have to shut it off manually each time, from the View Menu.
  • Hero Points: 141
Re: Config setting for Standard Find Next, and no minimap
« Reply #1 on: February 17, 2021, 04:56:38 pm »
1.  Go to Tools>Options>Keyboard and Mouse>Key Bindings> and for the Search by command type "find-next".  Then click Add...
2. Go to Tools>Options>Languages>All Languages>View, and at the right shut off "Show minimap".
slExplorer
« Reply #2 on: February 17, 2021, 06:08:21 pm »
All set, thank you sir.
