Author Topic: add-multiple-cursor-up/down broken  (Read 107 times)
jcelle
  • Hero Points: 4
« on: February 22, 2021, 05:39:14 pm »
Hello,
I am trying to add some multiple cursors using add-multiple-cursor-up/down functions. This has always been working fine for me.
Since a few days however when I invoke these functions the cursor just moves up or down, depending on the method I have used, but remains lonely.
A message appears in the bottom status bar : "Resetting multi-cursor because buffer was modified"
I have no idea what it means.
When I use Ctrl+LButtonDown I can instantiate mutliple cursors normally (though I am not able to visualize what function is bound to this mouse+key combination).
And more, if I use ctrl+left+shift+up/down that is bound to aforesaid add-multiple-cursor-up/down it clears the cursors leaving only one left, which is what I expect.
I was wondering if anyone was facing the same issue.
Any idea welcome.
Thanks for reading.
