Author Topic: independent window resizing  (Read 2429 times)
mschifterForum
« on: March 04, 2021, 07:17:18 PM »
It would be great if I could independently re-size each window buffer.
I realize some people may want the linking you have now, so I would request the new "mode" as an option.
My use case: when working on a class, I first open the header and then the cpp file. This makes implementation more convenient.
However, as I build out the methods, often I am using other classes, and I need to have those header and cpp files open in independent windows. Each file has it's own inherent width to see its content, and that will differ from file to file. So if this feature was implemented, I would use it all the time.
Thanks for listening,
Matt
  • Hero Points: 210
Re: independent window resizing
« Reply #1 on: March 04, 2021, 09:06:40 PM »
You can drag buffer windows out of the main slick edit window, and then each is independently movable and sizable
mschifterForum
« Reply #2 on: August 23, 2023, 03:28:40 PM »
not the same
  • Hero Points: 517
« Reply #3 on: August 24, 2023, 05:34:37 PM »
If you right-click on the document tabs, there are options to split windows (either vertical or horizontal).  Once split, you can grab the size-bar between them an drag to resize both windows.  You can also split windows (or tile windows) from the Window menu.
« Last Edit: August 24, 2023, 05:36:27 PM by Dennis »
