Author Topic: How to configure different build configuration: Debug and Release  (Read 1534 times)
aos
I want to have to different build configuration: Debug and Release.
I saw that I can change the configuration for each project i.e Debug/Release.
I do it by doing the following: Project Properties->choose the requested configuration in the "Settings for:"
Image attached.
But how can I change the configuration for all the project at once in order to build all the projects?
aos.
moatingodseye
Re: How to configure different build configuration: Debug and Release
« Reply #1 on: May 16, 2021, 09:20:24 am »
Hello,
If you go into project properties...
And then top right configurations...
And then choose the configuration you want and press the set active button at the bottom right.
Cheerio
