Author Topic: python f-string color coding problem with escaped braces  (Read 206 times)
  • Hero Points: 122
« on: April 09, 2021, 06:59:18 pm »
In a Python f-string if you want to print an actual opening curly brace one uses 2 curly braces in a row - {{
But this throws off the color coding in python.
Example attached.
  • Hero Points: 461
Re: python f-string color coding problem with escaped braces
« Reply #1 on: April 09, 2021, 07:59:19 pm »
Ah..we missed that. Thanks for posting
Hot fix add for this
  • Hero Points: 122
« Reply #2 on: April 09, 2021, 08:11:44 pm »
Thanks. It also happens when using f""" (triple quotes) as well, maybe you have the same code for handling triple quotes as single.
  • Hero Points: 461
« Reply #3 on: April 09, 2021, 08:21:54 pm »
It's the same problem for all the f-string definitions. I fixed them all.
